27" Wheels and Tyres - which ?
Hi All
I'd like to get some new 27" lightweight wheels for my Rory O'Brien.
I'd be grateful if you could give me some ideas; I'm not sure what is available nowadays or where from; or how much they might cost.
It is ages since I purchased any wheels or tyres and I'm out of touch with what is available for 27" wheels.
Can anyone suggest any lightweight wheels which are suitable for fairly fast roadwork on a fairly lightweight frame ? I'd also be pleased if I could find out a source(s) for such wheels. Within reason, cost is not really an issue.
I'd also like to know any recommendations for tyres.
Regards,
Andy
You will have a really hard job finding quality rims in 27 inch and I think its safe to say that sourcing quality 27 inch tyres will be close to impossible. The last bike to be manufactured with this size was a Cannondale Tourer in around 1988 if my memory serves. When I started in the trade in 1984 we were already advising people to abandon this soon to be obselete standard for the European equivalent, the now universal 700c.
The only problem you might encounter with a switch to 700c is whether your brakes have enough slot in them to drop the blocks, 700c have a slightly smaller outside diameter than 27 so you need to lower the blocks by about 6mm (or 1/4 inch, depending on your point of view....)
Going to 700c wheels is often the best solution but brake reach could be a problem or you may just want to keep the bike original.
Tyres shouldn't be a problem, Halfords stock 27"(630mm) Conti Dura Gatorskins and nutrak cheapies.
There are really good priced dutch alloy wheels availible, there not fantastic quality but are cheap and servicable or SJS cycles have a page full of branded rims which you could be as good as any reasonably priced 700c wheels.
sjs rims
John the Monkey
Frivolous Cyclist
Crewe
If the frame takes nut fitting, rather than recessed allen key brakes, I have a pair of Alhonga deep drops that I don't need (the drop is *just* too large for my frame, which is designed for 700C wheels). The drop on the Alhongas is 57mm - 75mm.
Let me know if you think you might be interested - they're unused (other than having been fitted to the bike once).
If you'd prefer to buy new, Spa Cycles sell them for £24 delivered, and were the cheapest place I could find when I looked.
rustychisel
Agree with all the above, and am in the process of phasing out my last 27" wheel on a fixed gear bike purely because of the lack of good tyres. Which is a pity 'cause I have some a couple of pairs of wheel with good rims; Mavic GP4 and Ambrosio 19.
The best I can find is IRC Triathlon tyres and they're not much good - wire beaded and somewhat unreliable. There's also Chen Yip from Thailand and they're cheap nasty shoot.
Go the 700c route and the world is your oyster.
John the Monkey
Frivolous Cyclist
Crewe
bianco said:
SJS sell the alhongas for 19.99
Bum - I couldn't find them when I looked. Ah well, Spa Cycles seemed to be nice people, so I don't feel too bad about paying a bit more.
Edit: The only Alhongas I could find on SJS are the Brompton ones - the cable enters at the bottom of the calipers on these, and the fitting can't be changed, as I understand it (I did turn them up looking for the ones I ended up buying from Spa Cycles).
harman_mogul
Inner London
Looks like you are committing to the 700C option with deep-drop brakes John? Mistake, in my view.
You can still get 27-inch rims, both at SJS Cycles (rather expensive) and at the eBay store Mario's Cycling Parts Shop. I bought two pairs of new old-stock Weinmanns from Mario recently and they built up just fine into good true wheels.
You can get modern-technology tyres from Continental (Gatorskin) and Panaracer (Pasela). Both are nominally 32-630 but the Conti actually comes up at 28mm width, and can be inflated hard. It's competitive for all but the hardest training.
The advantage of staying with the 27-inch rims is braking. The radius of a 630mm wheel is 4mm more than a 622mm. Doesn't sound much, but makes a huge difference to the leverage of the brakes. Tektro do a very decent double-pivot, bolt-on brake that works very well on the Weinmann rim.
I hope this will persuade some of the doubters not to abandon the old standard where it's clearly the righrt choice for the frame.
John the Monkey
Frivolous Cyclist
Crewe
Harman, I bought the Alhongas because my frame has quite deep drop brakes already, (although it does run 700C, and was designed to do so, it has clearance for quite big tyres and mudguards). I figured the Alhonga deep drops would be about right with the blocks set up near the top of the stirrups (sadly, I was wrong).
Oddly enough, I've now found some Tektro dual pivot brakes that are both nut fitting, and a more standard 49-57 drop, so will probably plump for those.
rustychisel
Tosh and piffle.
A huge difference in braking performance??????
I would love to see the calculations.
One of Cyclemagic's suppliers has loads of 27" tyres in stock but I'm not going to tell you where they are coz I'm going to buy them all up and push the price through the roof.;)
Mwahahahaha.
