Yes, you did strike a nerve. first of all, there's the issue of ettiquette. Dont burst into a room full of strangers with wild statements. We donb't know you yet. Introduce yourself, settle down a bit, test the water and then think about what you write.
As for your 29-er issue - yawn. Do a little search and you'll see you've attemted to flog an old horse. Remember, we've been here a while, you are not the first cowboy at this rodeo.
As for "a longer chain makes a major loss of energy!"
That's your claim, therefore I'd like you to come up with the said formula to prove that. Keep in mind that the chain (roller chain) is a field of study in mechanical engineering that's well understood and described in text books and online academic journals. Roller chain energy losses can be calculated and even measured. It should therefore be very easy for you to substantiate your claim if there is evidence that it is true. Try ChatGPT if you like - no need even for exclamation marks or the word "major" when designing your prompt.
