mattprince
Member
- Cheshire, UK
I would go for a hybrid without front suspension as a good start (all suspension adds on the road is extra weight and you lose power bobbing up and down). The Carrera Subway mentioned above is a good solid bike, and there are others around that would work as well.
I'm a couple stone lighter than you, but have been able to ride a road bike on 23mm tyres so don't worry about the bike being up to it, they tend to be tougher than you'd think. What you would be more likely to do at your size is to knock the wheels out of true so a spoke key would be a good investment. Also a pump that will get the tyres up to the maximum written on the sidewall of the tyre.
For £200-300 then you will probably get more second hand. Disk brakes are good, but don't discount rim brakes. V-brakes once set up on a decent bike shouldn't need much in the way of adjusting. I've used them, and cantilever brakes on my bikes for many 1000s of kms without any problems.
Whatever you get then make sure you are happy with it being the right size for you, and that you like it. You will be more likely to ride it if you like it.
Have fun, and soon you will be a 5-day a week commuter. You're about the same distance form work as I am. Then you will get to the stage where you start extending the ride home to make it longer![]()
So this one would be ok too? http://www.halfords.com/webapp/wcs/...uctId_912123_langId_-1_categoryId_165534#tab3
