ChrisEyles
- Devon
Red wheels, as promised:
Just need to buy a couple of replacement bolts that sheared off when I stripped the frame down, and then I can re-assemble
I'm still missing the front rod brake stirrup - I found a possible replacement part, but not sure if I can make use of it... because I can't seem to remove the old (broken) front brake! It *looks* like once you've loosened the locking nut (not pictured below, I've taken it off) the brake part should slide off the thinner rod (which is attached to the brake lever on the bars). Am I missing something silly here..?
