Simba
Specialized Allez 24 Rider
- Tottington - Lancashire
They have been approved by the government, the source was in Cycling Weekly. As if the 16 metre ones aren't bad enough for us.
The amount of cornering clearance required is a direct product of the longest section, so the new longer trailers will need more cornering space.
In particular, the rear overhang is greater, and this means that the tail will swing further out in the opposite direction of the turn.
Junctions all over the country have been designed based on the previous vehicle geometry, so the new longer vehicles will need more space than is actually designed into the road layout.
Not only that, it's desirable that junctions are redesigned to 'tighten up' the junction geometry in order to force turning vehicles to slow down - thus making junctions safer for cyclists and pedestrians. The DfT itself recognises that junctions are a particular hazard for cyclists ("Seventy per cent of injury accidents involving cyclists take place at junctions...", para 9.5.1, 'Cycle Infrastructure Design', LTN 2/08, October 2008).
The question then arises as to why the DfT is - rightly - supporting improved design of junctions in order to make our roads safer while at the same time allowing the use of vehicles the design and dimensions of which are unsuitable for these safer designs and which will tend to encourage highway engineers to design (or continue to accept) inherently unsafe junction designs.
It is often possible to tighten up junction geometry to reduce speed while proving an over-run area, using raised setts for example, to allow long vehicles space to turn slowly.
