Ajax Bay
- East Devon
Yes, same freehub splines. A long cage RD has the distance between jockey wheel centres at about 88mm. You'll need that length cage for the 11-32 for wrap capacity. It's likely even though out of spec (I think) that judicious use of the 'b screw' will pull the guide jockey wheel low enough to avoid interference with the 32t sprocket.
For fitting you should not need to change the indexing: start from where you are, and tweak cable tension. New chain definitely needed, probably 2 inch links longer if current chain is correct length (or use chain round large and large and not through RD and add one inch link).
I now see @T4tomo has said much of this but just say that although 25t > 32t = 7t, the chain only goes round half the sprocket so 7/2 = 3.75, call it 4 more and that's 2 inch long links.
