roadiewill
- Wiltshire
meh, nope not working. Have to take it to my not so local lbs tomorow
Euan Uzami said:for the tension, get the chain on the small front ring and large rear sprocket. i.e lowest gear.
pull cable hand tight, then fix cable by tightening the bolt holding it.
then tighten the cable with the barrel adjuster until it will shift onto the other chainrings satisfactorily.
secretsquirrell said:you need to make the 105 shifter was in the correct position for the small chain ring, then repeat the above process and it should work.
roadiewill said:cheers guys but I took it to the LBS and apparently it was a faulty shifter. The problems quite commoon apparently on the 105 shifters, as shimano have mad them to work with both triple and compact chainsets. Sometimes the extra click on a double confuses it and causes it to break... somehow :?
