Chain ring bolts pass through these predrilled holes but then are secured by engaging in sleeve nuts (which have a slot in them to allow a screwdriver to prevent their unwanted rotation). The use of threadlock is sensible.
All I was saying is that chainring bolts are NOT 'two piece'. How could they be? I do not wish to call them 'screws'.
To secure two rings (eg outer and middle in a triple) with the same BCD a bolt and a sleeve nut is used (x 4 or 5). One ring eg the inner on a triple crankset, is secured by just a bolt is used (a 'one piece bolt'
)(x 5 normally).
Nut - A fastener with female threads,
Bolt - A fastener with male threads, usually with a hexagonal head. Strictly speaking, it's only a bolt if the threads do not extend the full length of the shaft.
If the threads do extend full length, technically it is a "
screw " but only pedants insist on this distinction.
https://spacycles.co.uk/m2b0s173p3399/SPA-CYCLES-Chainring-bolts-(head)-x5
https://spacycles.co.uk/m2b0s173p3400/SPA-CYCLES-Chainring-bolts-(sleeve)-x5
