Angelfishsolo
A Velocipedian
- Cwmbach, South Wales
I have used Shimano XT for 15 years and it has served me very well.
Yes but I asked about XTR v SLX
Yes, that is my opinion and I always buy the best I can afford whether it be a bike or whatever. Experience has taught me that it is usually the cheapest option in the long run.
You're confusing your two stances. On the one hand you're saying you like expensive equipment, you won't settle for anything less. Fine - me too, on occasions.
On the other, you're saying "I still think £400 is too little to spend for serious off-road use," without backing it up. If it's the case that you personally wouldn't spend £400, because you like expensive equipment, that's something different to saying, unequivocally, that a £400 hardtail is "unsuitable for serious off-road use."
Being as I originally asked for opinions and advice on £400 hardtails, if you have serious concerns about the quality of the components/manufacture on bikes in that price range, I'd be interested to hear, specifically, what they are.
If you're simply saying "don't buy a £400 bike because a £2000 one would be better"... well, I could have quite happily done without that, to be honest.
You also asked about my experience.
Regarding XTR v SLX, I would say that the current generation of SLX is excellent and probably equivalent in build quality to XT, say, 5/6 years ago. XTR is primarily intended as a race groupset, I believe, which I think rules it out of this discussion.
Percy - seriously you will have no issues with a £400 bike on trails I assure you. You might get slicker gear changes and slightly better brakes on a more expensive machine and yes the forks will not be as good as say a £1000 fox fork but they will do the job you require from them. CJB seems to be a expensive is best person and if he can afford it so be it.
It is indeed. Thus suggesting that someone spends as much as possible would lead someone to buy a bike with and XTR group-set would it not?
I don't think I have said, in any of my posts, that one should spend as much as possible.
mean?Yes, that is my opinion and I always buy the best I can afford whether it be a bike or whatever. Experience has taught me that it is usually the cheapest option in the long run.
So what does
mean?
Also the Decathlon website has been moved so that amazing £500 bike is still available here
It says best, not the most expensive
But XTR is the best that Shimano make!
I have one of those cost £359 and has been completely reliable.Have noticed Spesh Hardrock's going for £350ish on a few sites, don't know a lot about MTB's but for a budget bike it seems OK to me.
Got me wondering now whether to keep to the plan of a CX or switch to a HT MTB![]()
You are just willy waving about how much money you claim to spend spend to get "the best" when you probably can't even ride at a level to even need most of the features offered, it's just an expensive security blanket.What point are you trying to make?
I am talking about best for intended purpose here, which in this case is recreational mountain biking. As I previously stated, I would certainly buy XTR if I raced regularly.
