Yellow Saddle
"There is a compressive force between road and bike." Like the compressive force in the sole of a worn shoe. Difference is that the wheel is a structure so saying that "there is a compressive force between road and bike" lacks meaning/utility.
I'm not sure what worn shoe or structure has to do with it. I don't get your argument here at all.
"The only spokes that interact to transmit that net downward force are the ones in the load affected zone, i.e the two or three right at the bottom." Depends what you want "interact" to mean. I agree that they're the ones in which tension reduces most, which means they pull down on the hub less than when the wheel is unloaded.
Interact means that they act in a way to support the load. That way is to reduce in tension. None of the other spokes have anything to do with the load, they do exactly what they do as when the wheel is unloaded.
"The other radial forces in the other spokes play no role in transmitting the bike's weight down to the road. None."
Sorry, I have difficulty with that. The hub is 'hanging' on the spokes above it and the upwards force it has to exert on the fork drop outs is because the lower spokes have reduced the amount they are pulling down.
No the hub does not hang on the top spokes. That implies an increase in tension, which doesn't happen. An analogy is to look at a car wheel and tyre. Only the bottom squashes down, the top doesn't somehow become fatter/elongate because the rim is hanging on it.
To get your head around it, remove your front wheel and hold it by the axle, vertically, with two hands, each one side of the wheel. Push the wheel down on the floor by the axle. Now imagine your "hanging" hub. Now, pick up the wheel, turn it horizontally and do the same as before, but push against a wall. What happened to the "hanging" hub.
To prove this experimentally, find two friends to help you. Sit on the bike and have one friend hold you upright. Have the other pluck the bottom spoke and listen to the tone. Unload the bike and listen again. Now sit again and pluck the top spoke. Unload and pluck again. You'll notice that the top tone never changes but the bottom one goes down in frequency when the bike is loaded.
The lower spokes just experience a cyclical lower tension - the force exerted on a lower spoke by the rim lessens and results in a lower tensile force. This means that the resultant force (the result of all the spokes pulling on the hub at various tensions) on the hub is up (ie operates vertically upwards through the drop outs and is equal to the weight on the wheel).
Please rephrase, I can't comprehend.
I think we agree what happens but I think your use of certain terms (like compression, compressive and 'stands') clouds rather than provides the clarity needed for "a better understanding of this complex but fascinating topic".
That's not my problem. I've explained my meaning of those terms and so far no-one has come up with more appropriate ones. Those are exactly the same terms used in the literature on the topic and accepted by those who understand the concept.
