Can anyone riddle me this one please?
A two bedroom flat has an aerial in the loft that connects to a booster with three outputs, one connected to the living room, and the other two connected to a bedroom each.
At the moment there's no faceplate in the living room, just a back box with a cable dangling out of it.
A TV was plugged into bedroom two to confirm that there was good reception, all five terrestrial channels came through with a good picture, the TV's a none smart Toshiba that's about ten years old.
Bedroom two face plate was removed and fitted to the blank back box in the living room and the TV connected to it using the same cable that was used to connect to the socket in bedroom two.
Now all that comes through is ITV, C4, and C5, there's no BBC1 or 2.
The only difference is the output on the booster, and the cable from the booster to the wall socket.
It's probably going to be Monday before I get round there with a new faceplate for bedroom two, when I'll then connect a TV to that and see what the result is, my other plan is to swap the cable running to the living room to a different booster output, anyone seem this before?
It must be about thirty five years since I last played with coax cable.
