IanSmithCSE
- Worcester, Worcestershire
Good morning,
I have had my first week of commuting on the Ribble and despite my negative initial impressions it has done what I wanted it to do and taken the edge off the commute.
It is a bit tricky to come to conclusions on how much assist I would normally be using as the temperature has dropped to -5C and the canal behind the house has frozen over meaning that I have been cautious on the rides. Battery usage is all over the place ranging from 5% on one leg to nearly 40% on another as I poddled along scaning for the next patch of ice.
Checking the app as soon as I arrived at work on Friday morning sees +3C for the battery and -1C for the motor and given that I would expect both of these to be generating some heat as they dischare/rotate I am clearly outside of the ideal operating tempeature.
At 14kg (31.5lbs) it is heavy by modern standards for an aluminium "racer", much less so if we consider the Raleigh Royal at 29.5lbs
Out of an interest in not losing too much fitness I rode it home with the motor turned off all the time on Thurs/Fri and I did notice this weight on some of the uphill bits, but it was no great issue.
I am getting noticable drag from the rear wheel when the power is off and pedalling hard, both all the time and when going over the assist limit. As this drag appears and disappears I took the rear brake pads out and went for a ride to rule out any brake issues and it clearly does seem to be a brake issue. Removing the pads gives another half a revolution to the rear wheel, about 2 revs for a non trivial spin and I am quite happy to accept that as effectively zero resistance. It also means that the brakes are not binding all the time.
I will see if this drag disappears after a few more miles or if just removing the pads and reinserting them has helped. These are my first disc brakes so I expect that it will take me a bit longer to sort out the issue but it does feel like some sort of deformation under load. The wheel slows down uniformly when spun by hand without an obvious spot where the disc is warped.
Or maybe it is just a sensible bike and it doesn't like being out below 0C!
Sadly I still struggle with the STI front shifter, with finger and wrist pain returning on the Thurs/Fri unassisted ride, this isn't an issue when the motor is on as I don't use the 34t inner ring. Why did they fit such a thing and as Ribble have been slowly removing options from the bike builder the choice was 50/34?
Although named "Endurance" I am finding the overall geometry to be quite racey especially out of the sadle, but still comfortable.
The one buttom iWoc remains a problem if I want to change assist mid ride, it requires too much loss of concentration on the road to be truly safe as you have to cycle through all four modes rather than go up or down. This cycling also tends to result in a bit of jerk when you go from full assist to no assist. There is the Pulsar One cycle computer but there are lots of comment about compatabilty between it and the bike.
So I am slowly warming towards it as tool rather than a recreational bike, I am even contemplating a rack for light loads. Sadly with the short seat stays and no eyes but a threaded hole in the chainstay bridge getting one level might means some "adjustments" will be needed. Mounting a second rear light on the stays is also a problem for my existing lights as I can't get them vertical, it's too late this year to buy new ones so I have seat post one and the less effective seat stay one.
[Edit]
I have also added two bottle cages and they have made plugging in the charging cable harder, the bottom of the seat tube cage leaves enough room for the cable but only enough. The plus side is that I can carry a decent set of tools and I have used up another 2 cages and 1 bottle from the 12 that I bought off an auction site.
[EndEdit]
Bye
Ian
[Edit]
[EndEdit]
Bye
Ian
