Spiderweb
Not So Special One
I run 3 bikes with Shimano 105 short cage rear mech, I’ve swapped all the rear cassettes to Ultegra CS6700 12-30t and they work perfectly.
That's a good price for a R7000 crankset.Currently I see two good options. One is the Shimano r7000 compact 50/34 which I can pickup for £50. If in the future I wanted subcompact gearing I could add the Absolute Black 46/30 rings to that (at a cost of £180). The front derailleur will work if I add a derailleur dropper for £39. Don't need to change anything else on the bike unless I want to go for bigger rear cassette than a 29, in which case I'd near a new rear derailleur.
I don't know about the chainline but the chainset difference is likely to be because the GRX groupset is designed to work on a 135mm OLD hub from a disc braked bike, so the 2.5mm offset makes sense. I wouldn't expect there to be much of an impact if any, but the only way to find out is either to do it yourself or for someone who already has done so to comment.The chainset is 2.5mm wider which is why I need the derailleurs but they're not that expensive. However, is that going to be an issue with the chainline? I'm hoping not if I'm using the appropriate derailleurs. It would also mean I could go for larger rear sprockets as the rear derailleur is designed for those. My current 10sp ultegra shifters will work with this system. Looks like a good budget upgrade with standard parts and chainrings easily obtainable in 110 size.
If you get a left side only power meter you can put it onto any HT2 crankset provided the arm length is correct and aside from an aesthetic mismatch there shouldn't be any issue.Another thing is that if I want to get the 4iiii power meter at some point, it can be fitted to the 105 crank and the GRX RX810 but they don't show the RX600 on the compatibility list. Need to email them about that.
Ah that's useful to know. When I looked up the spec on the current RD, it says 27T was the largest it could go so figured I'd need a newer one for getting up to say 30T if I went that route.By "The chainset is 2.5mm wider" think you mean the chainline. Will have zero noticeable effect on your 105's operation.
Aha, thank you, that's handy to know.The height you can adjust your FD to is an issue with a small 'large' ring, which you've referred to upthread. I assume this from SJS is the dropper (39 quid whooof). Spa Cycles option (@£18) : https://www.spacycles.co.uk/m8b0s106p5161/SPA-CYCLES-Front-Mech-Braze-On-Dropper and it's black
I'll give that a try.The extra 2.5mm is likely within range of the current (silver) FD - but you can check the lateral reach by unscrewing the upper limit screw and pushing it across by hand (and then returning screw to current position for changes on the turbo).
See above for explanation.With all the expense you envisage I wonder if investment in a 20 year old bike is sunk money and you'd be better off with N+1.
I think I'm right in saying this won't work with your current shifters. Someone here should be able to advise.GRX RX400 10sp rear derailleur - £59
I read (variable geometry, beam suspension" earlier and wondered. What an amazing bike. I can see why you need to go 'all black' with derailleurs and chainset. While you're at it, get some cable under bar 10sp STIs. And some black speedplays.my road bike . . . is a thing of beauty and quite rare. It's a Titanflex, aluminium monocoque with titanium beam, so it's variable geometry and has suspension.
You have highlighted the 105 9 speed version, while what he has said before suggests he has the 10 speed version.
Well, it's ok buying stuff just to try it out if you have money to throw away when it doesn't work. If there's leeway in hand it'll likely be there to absorb tolerances.I think we all know Shimano always tend to err on the cautious side @presta . Like I said 'Suck it and see'. You'll soon find out.
Alternatively and the one I'm leaning towards, go fully Shimano sub-compact gravel setup as follows.
GRX RX600 10sp in 46/30 - £90
GRX RX400 10sp front derailleur - £27
Total £176 plus shipping
