Changing from 11-28 to either 11-32 or 11-34 cassette...
si_c
Wirral
Is the same gear cable used for both road bikes and MTBs? It's not specific to each, is it?
Gear cables are usually interchangeable, brake cables not so much.
Dogtrousers
Kilometre nibbler
Generally yes. Although it can vary. I do seem to remember that the fine print of my SRAM Apex shifters specified a marginally skinnier cable than the usual standard for Shimano shifters. Can't remember the actual numbers.
Mazz
Mazz
Leicester
UPDATE: front chainring is 50-34 Tiagra, current rear cassette is 11-28 Tiagra (10 speed).
Replacement cassette is 11-34 Tiagra (10 speed) and I will be replacing the chain at the same time.
QUESTION: Do I need to make the new chain a couple of links longer to account for the largest cog on the back? Thanks
Dogtrousers
Kilometre nibbler
Yes.
There are ways to measure the correct chain length. Someone with a better memory than me will be along in a bit.
Dogtrousers
Kilometre nibbler
Are you referring to the total number of teeth on the 2 rings (biggest front plus biggest back) +2?
Thread the chain round the big ring and the big sprocket but not thru the mech. See how much chain that needs. Then add 2 full links. Or four half links.
And, if your previous chain length was right that should be 2 full links more than what it was before.
I think
