XT M8000 shifters and BL-M8100 levers
mikehave
Hi, I'm doing a flat bar bike build, I have an issue; I have Deore XT BL-M8100 brake levers, and a Deore XT M8000 11 speed shifter, with a bar clamp. How do I fit these onto the bar, as neat as possible? Ideally just one clamp. Do I need a mount to convert ?
I accept these components are not as compatible they should be !
iluvmybike
If your shifter is the I-spec version you can mount the brake lever on it by removing the window but if it isn't then you can't
