Woops a server error occured
richardfm
Cardiff
Both yesterday and today I have been getting an error liking posts in the Daily Wordle thread.
It doesn't happen on all posts, maybe 40%.
I "like" a post and get a message saying "woops a server error occured". If I try again there is no error message but the post isn't liked. If I try a third time the error returns.
sevenfourate
Devotee of OCD
Putins chucked a spanner in the works i reckon. The Electronic war against the UK has begun........
Alex321
South Wales
This is probably the same error as is causing the double posts - https://www.cyclechat.net/threads/double-posting.300343/unread
Don't try again, just refresh the page, you will probably find the "like" has stuck.
classic33
Leg End Member
Same applies if you are posting a new thread or replying to a thread.
Doing that gets this message
Page not found
Sorry, the requested page or resource could not be found.
Try SEARCHING to see if you can find it.
Or maybe BROWSE OUR FORUMS to see if what you are looking for is mentioned in any of our discussion threads.
Ming the Merciless
There is no mercy
Inside my skull
Generally caused by a glitch in the matrix!
Dogtrousers
Lefty tighty. Get it righty.
Page not found
Hmm. Just refreshing has always worked for me.
I'm pretty sure (from my own experience) that the duplicate posts aren't caused by the system. They are caused by people posting multiple times as a result of being confused by the error message.
Widnes
Just seen a post saying it seems to be fixed
but I just got another server error - clicked again then I had 2 posts
I did delete the second so tha's sorted
just saying so site support know
T4tomo
yes its still a bit farked. ignore error warnings. if you thne refresh the thread your post has posted but also remans as a draft to psot (at least on the web version) mobile may be difo.
Dogtrousers
No, it's the same on mobile. Replies get posted but the draft psot is still there.
Glasgow
Mod Note:
Sorry about the duplicates, this should be getting fixed during the weekend.
Correct.
It will be fixed during the weekend: our forum founder, IT wizard Shaun, will get his spanners out :smile:
Correct.
