Wobbling back into cycling...
Boo
Enfield
I picked my new bike up yesterday! And after finishing tidying out the garage, I went out for my first, short, shakedown ride.
I haven't ridden a bike for at least 7 years (well, other than my ongoing, and so far completely unsuccessful attempts to master the unicycle). And my old bike was a 1980's 'racer'. This was a modern, light hybrid.
What a revelation...
The first thing that struck me was the progress that has been made in materials technology in the intervening years since I last partook of bicycling. The scientific community have, against all odds, managed to develop a substance that's harder than diamond, and joyously, Specialized have decided to use that to make my saddle! Suddenly that £40-odd on a decent pair of padded shorts was looking less like an extravagance and more like a matter of life and death.
The second thing that struck me was a line from Douglas Adams's finest hour, "The Restaurant at the End of The Universe". Two of our heroes are up to no good in the garage of said eatery, and have found a sleek looking spaceship, which they are about to make off with.
"Feel it." said Zaphod.
Ford put out his hand. "You can't. It's totally frictionless. This must be one mother of a mover..."
I was amazed. A combination of the lightness of the bike, the 110lbs of pressure in the (fairly narrow) tyres, which was probably a good 50lbs more than I ever put in my old steed, and the fact that everything was new, and therefore didn't rattle or clunk, meant that riding it for the first time was a very strange experience indeed. The thought that kept crossing my mind was that it was like riding on ice - there didn't seem to be much contact with the ground at all. I guess this is a good thing, although at the time, it made for a fairly... uneasy experience. Combine that with a far more upright riding position, and a considerably higher saddle position (i.e. where it ought to be) than I used to have, and for the first 500 yards, I felt like one of those baby foals that you see in the seconds after their birth, legs splayed out every which way, and looking particularly ungainly.
Fortunately I was on some very quiet roads.
But I gained a bit of confidence, found a straight, flat bit of road and tried to remember what the manual had said about how the gears work.
I then recalled something about "Different bikes have different gear systems - talk to your dealer if you are unfamiliar with the way your bike works." Bit late for that now! I decided to push the big lever by my right thumb and see what happened.
Well the pedalling just got easier, so I'm guessing that was a downshift. Upshifts, however...
Upshifts seem to be hidden away under the handlebars, just at the reach of my index finger. I'm sure I'll get used to it.
My left thumb wanted to have a go too, so.... whoah!
Suddenly my legs are going round like Wile E. Coyote in the moment after he's just run off the edge off a cliff, but gravity hasn't beckoned him groundward yet. I suspect that particular ring of the chainset is only ever going to get used for going up hills.
Flipping a few more gears, onto the largest chainring and the smallest cog of the cassette, and I'm beginning to see why my friends said they dumped their hybrid after 6 months and bought a road bike. It's as though there ought to to have been somewhere else to go, another chainring.
Then I reminded myself that I didn't buy this for speed, I bought this to enjoy leisurely rides and get some exercise.
Meanwhile, the reflector at the front had clearly not been tightened enough and was threatening to fall off, and not having any tools with me, I decided to turn round and head back. Besides, my heart rate had gone up to the sort of tempo usually reserved for hardcore Scandinavian techno, and I didn't want to kill myself on my first ride.
I dismounted at home, having covered no more than two miles, and nearly fell over. During the past 10 mins or so, someone had replaced all the bones in my legs with jelly!
Unfit? Moi?
Maybe just a little.
Having fixed the reflector, and said to my wife, through heaving gasps, how much better I felt for getting some exercise, I went for a sit down with a glass of Lucozade.
I could get used to this cycling lark!
winjim
Absolutely nothing wrong with hardcore Scandinavian techno ^_^
I like Skol
A Minging Manc...
Sounds like you are headed in the right direction there Boo (Can't say that without thinking of Monsters Inc.).
As far as gearing goes just avoid using big/big and small/small combinations and you have it worked out just fine. If the big chainring and smallest rear sprocket doesn't give you enough speed (remember, maybe you are not used to pedalling fast enough yet) then check your cassette has an 11 tooth smallest sprocket. If it is a 12 or 13 you can have this changed quite cheaply. Cassettes are available for around £15-30 in most combinations.
bengdis
Regular
Coventry
Boo, I did pretty much the same as you on Saturday - Albeit, not having ridden for around 3 years - I covered 14 miles in an hour and a quarter....
Legs aching - I arrived at Starbucks and had some of the fattest coffee options available!! Then got home and cracked open a bottle of wine.... None of this Lucozade stuff you talk about - only hardcore caffeine and alcohol....
Good on you for getting back to it - that's what I'm telling myself now, even though I can't sit down as Dawes have made my saddle of that 'harder than diamond' material .... WELL DONE! ^_^
raleighnut
Unfit? Moi?
Sounds like you got one with a "compact" gear set!
NEO
lancashire
We'll done boo it's all worth it in the end even though I've just got off my road bike looking like John Wayne :smile::bicycle:
NealM
Cheshire
Brilliant write up on the re-introduction to cycling .. Sums up how I felt about 10 months ago ..
Welcome !!
summerdays
Cycling in the sun
Bristol
I enjoyed reading that, it's good to have it written down, come back in a few months and reread it to remind yourself of the beginning.
Boo
Boo
Enfield
"Not too much too soon." I'd told myself. "You're as fit as a very unfit thing."
So having given myself the best part of 72 hours to recover from the whole 2 miles that I'd ridden on Sunday, when we got home tonight, I announced to Mrs Boo that I was going out for a half hour ride. Moments later, the doorbell rang.
It was a courier, who handed over a letter, which I tore open.
"Please!" it said. "Please have pity! Don't make me go back on that saddle. I've always been behind you , I've always supported you - don't do this to me!"
Sincerely,
Your backside.
But my determination to get fit prevailed and I got suited up, saddled up and off I went. I'd only been going a couple of minutes when four lycra clad types on road bikes went past me like I was standing still.
Although if we're rounding to the nearest 10mph, then technically I was standing still.
Anyway, I found myself a quiet road and decided to practice looking back over my shoulder without wobbling for a few minutes. Well I didn't fall off! I'll take any positives I can get at the moment, but definitely some more work needed before it's second nature.
Up until know, everything I'd done was on the flat, so I turned round and headed for a nearby country road with a good sized dip in it. Going downhill? I'm all over that! I've got that down cold. I could go downhill all day!
Then the dip bottomed out, and the inevitable uphill bit arrived.
Remember how I thought that smallest chainring was a waste of time? What did I know? I was changing down like it was going out of fashion and the Swedish techno band had taken up residency in my chest again.
Only about 100 yards to the next flat bit.
Only 99 yards to the next flat bit.
Only...
Oh gosh. Does my shoelace need doing up? Why yes, yes I think it does. I'd better stop for a minute and do it up.
And look at the time! Better be heading back.
That hill that I'd whizzed down a few minutes back? I've driven up that rise a thousand times, and I swear it was never that steep. In the interests of making it back alive, I had to get off and push for the last third.
But next time? Next time I'll make it the whole way up.
I got back to the flat and level. The dear, sweet flat. How great are flat roads? Very great. Very great indeed. Another 10 mins or so and I made it home having completed my half hour.
There was a note pinned to the garage door:
"This is your legs." it said. "We're with your backside..."
