Deleted member 23692
I need to make a bit of room for other stuff, so I'm having a clear out.
Token hollowtech alloy pre-tension cap Replaces the plastic pre-tension cap in 20mm thread axles (105 and above), so you can use a 8mm hex key instead of the flower shaped Shimano tool. I bought this thinking it would fit a Tiagra axle but it doesn't as it's 15mm thread.
£5 delivered (UK mainland)
