Will swap my Campy Ultratorque Mirage Compact crankset for similar Campy taper compact crank
chriscross1966
Swindon
*** Now found a taper crank, Mirage still available if you're interested**
I've got an Ultratorque (not the Powertorque) Mirage crankset complete with decent bearings, bracket cups and fittings plus a pair of decent chainrings (can't remember if they're Campy, Stronglight or TA, but ho hum, I'll dig them out). I want a Campagnolo square-taper fitting compact crank set, don't care about the presence or absence of a bottom bracket or chainrings. I'm not expecting a set of Super-Record carbons, the Xenon or Mirage, preferably in silver finish would be fine.
Straight swap preferred, I'll chuck some cash in for the Record or Chorus Carbons. I'm in Oxford in the day, Swindon in the evening and I'm happy to travel to you. I'll be up near Derby at the end of the month if it helps.
I'll get some pictures sorted out.
