will i need to move the front mech...
S-Express
Depends how much clearance there already is.
Sharky
Kent
I knew there was a reason for learning geometry at school now after 48 years I've found it.
Cirmcumference = 2 pie R
so R = Circumference / 2 pie
so 53*0.5 / 2* pie - 52 *0.5 /2* pie = "not a lot"
Loch side.
Geometry is very clear in this. It says maybe.
Precise science aside, surely, if you have enough tech savvy to remove and replace a chainring, you have enough skills to loosen a FD and move it up a fraction?
You'll likely have some adjustment with a new cranks for shifting but you might just get away with not moving the mech up if you have enough gap.
ianrauk
Tattooed Beat Messiah
Rides Ti2
Ajax Bay
East Devon
There was a reason, @Sharky - so why didn't you? Number of teeth is not 'r'.
Radius of a '53' is 108mm. Radius of a 52 is therefore 108 x52 /53 (= ~106mm).
Hence @User 's 2mm recommendation, with the probably / "if the mech is in the right position to start with" caveat.
Dogtrousers
Kilometre nibbler
@Sharky 's forumula for the radius of a 53 is pretty good I thought: 53*0.5 / 2* pie gives 4.21" or 107.1 mm. The overall delta formula 53*0.5 / 2* pie - 52 *0.5 /2* pie = "not a lot" gives a delta of 0.08" or 2mm - in line with what @User suggested.
