Will I be able to fit largest size Shwalbe marathon plus to my rims
Hi all. The tyres on my wheels are 26 x 1.90 and I would like to fit some Shwalbe Marathon Plus's oweing to thier p*****re restiance but the largest size I can find is 26 x 1.75 would these be all right to fit on my wheels. If it is OK it would help as the 1.90's are a tight squeeze to get out of the brake arms. Many Thanks.
TheDoctor
The TerrorVortex
They'll be fine. They're only 4 mm narrower, so there'll be no problem at all.
Joe24
Nottingham
For the brakes, there should be a thing that you either twist and the brakes open out(dual pivot brakes) or you squeeze them together and release the cable from one arm and the brakes open out.
4F
Suffolk.
Headgardener said:
Right sub question. As you can see by my location I live on the edge of The New Forest so would the above tyres be suitable for riding on the gravel tracks through the forest as well as on road.
What are you using at the moment on the gravel track ?
andrew_s
Gloucester
If the forest tracks are anything like last time I went on them (freshly covered in crushed flint), they will be very suitable.
Mr Pig
You can ride off road with slick tyres no problem. You simply fall off more often :0)
