wider tyres for an 09 Boardman Hybrid Pro ?
I think the subject heading speaks for itself :biggrin:
My first post and ordinarily I hate it to be a question......but this weekend has left me no options....sorry for that.
Sooo Im a n00b ;) I purchased a hybrid pro in a way that only someone special like me can do......i looked on the Halfords website, (cycle to work scheme) took some advice from guys that cycle to work and ordered it without looking......GENIUS!
Now....it must be said that I love the bike to cycle to work....its all roads and not very far.
Interestingly enough...not knowing bugger all about bikes and not riding anything since i was a kid (20 years ago) i had no idea that 18 gears only meant 14 odd useable :laugh: I took this as Halfords staff not having a clue ant took the bike to my LBS to de-halfordise and setup correctly. £40 bucks later for a service I find the bike in worse shape than before it went to then.....in this case Halfords staff came out on top. Interestingly I only found out about the less gears through the mighty Google.
OMG im waffling........So to my original point....although I love my bike on roads..... im surrounded by Eton and Windsor with some really great scenic cycle paths which I tried this weekend to find them more gravel track than smooth paved paths. Im pretty sure that this bike wasnt designed for this kinda terrain and dont wanna risk a blowout of a 120psi tyre thats built like a razor soooooo :
Can I put bigger tyres on this bike ? something that will cope with more than a glass surface ?
All advice would super super appreciated.
Of course I could be a tad paranoid and in fact this bike might stand up to more than i give it credit for.....but better stay on the side of caution.
Cheers
Craig
marinyork
Resting in suspended Animation
Logopolis
Go to your boardman and see what it says is the internal rim size. It will be printed in very small letters e.g. 700x19 perhaps in white or black.
M+ (not that I recommend them) can go fairly small so if the rim is wide enough should take 700x25 Marathon Pluses.
E
Error
Hi, thanks for the response, they would be 700x28c
Cheers
Craig
marinyork
Logopolis
That'll be the tyres, not the rims. In anycase the answer is yes, there are a wide range of tyres you can put on. 700x28 tyres or if the rims are large enough something else. M+ or anything below that in reinforcement.
I'd have thought 700x28s wouldn't be too bad on cycle paths?
E
Error
I think i need to go see a bike shop and check out a range to see whats available.
Im guessing the tyres are the only restricting factor when wanting to put a road biased hybrid on track type cycle paths ?
Thanks for the help so far ;)
Cheers
Craig
Garz
Squat Member
Down
Yes it was a bad decision but we all live and learn! Good luck Error on the new tyres!
youngoldbloke
28mm (width) tyres are not narrow. In fact they wouldn't even fit on a performance road bike due to lack of frame clearance. Most such bikes will be shod with 23mm tyres, and I have ridden roughish cycle paths with 19mm clinchers - not recommended, mind you! If you fit tyres which are too clunky you are going to compromise your (mostly?) on-road performance.
E
Error
so do we think that these tyres (maxxis detonators 700x28) are OK to ride on these cycle paths? I do ride only on road 5 days a week and err im not exactly the most fit or aerodynamic of guys (unless ball-shaped counts), did i mention my workplace in like 3 miles from my house?
the thing is theres sooo much nice scenery around near where i live and its all cycle path, i just dont want to miss out because of a possible tyre issue.
...Razor blade :rolleyes: my last bike was a Yamaha R1 so compared to this it definately is.
Cheers
Craig
marinyork
Logopolis
I'm not familiar with those tyres. However most 28s should be reasonably suitable for bike paths. Depends on the quality really. If it is reasonably flat mud and micro gravel it should be fine.
HJ
Cycling in Scotland
Auld Reekie
I can see a problem with tyre width, there is no reason why they wouldn't be at risk. I ride with 25mm Conti GatorSkins and haven't had an unplanned deflation events in over a year. I have been known to ride forest road at speed without problems, but I don't recommend that you try this...
The important thing is to keep them well pumped up.
jig-sore
Formerly the anorak
Rugby
my hybrid is fitted with 700x40c Michelin City tyres. some would consider these to be massive but i find them perfect.
the larger size gives a lot of cushioning and are very comfortable to ride on, especially if your on the large size.
some people will say these will slow you down on the road, but I've averaged 19mph on my way home before
you can buy duel tread tyres that have a slick tread in the centre and off road tread on the outer edges. I'm not too sure how effective these are and they may be overkill if you spend 99% of your time on the road.
Cubist
Still wavin'
Ovver 'thill
If you do mainly road riding then the Boardman wasn't a bad recommendation. The 28s are plenty wide enough. If you're going to ride them on anything other than smooth tarmac, you only need them pumped up to about 90 front 100 rear. Any more and you'll feel every granite chip in the surface.
Fact of life with the gears I'm afraid, you'll always get overlapping gears in the middle of the cassette, but trust me, the 09 Pro has plenty of gears. The steepest hill on my ride home (or should I say every time I ride home.....) is about 20% at its steepest point, and even I can grind up that, so anything less .....!
