Xiorell
- Merthyr, Wales
I've noticed alot of race/road bikes only have 2 chainrings, even expensive ones.
Why is this when many MTBs etc have 3?
I'm new to this road bike thing but as I understand it, two chainrings are lighter than three, it's known as a compact,
I was just curious about this, in my limited knowledge I'd have thought race type bikes want more gears. I stand corrected
My Verenti came with a compact chainset, 50/34, and 12-27 10 speed on the back, I changed the front chain rings to 48/42 to give me a set of gears that suited my legs better, and give me a chance of staying with the group on hills, using a 34 tooth front ring on a hill would have shot me straight out the back. Traditionally its been triple on the front for touring and double on the front for fast club rides and racing.
In my limited experience, I initially found the jump between the small and the large chainrings to be fairly massive, but I think I was using it wrong. That's because I was restricting the big ring to only getting used once I had ran out of gears on the little ring and ended up making a big jump between the chainrings.
What I'm doing now is setting off and pretty much getting into the big ring as soon as possible but in conjunction with a fairly short gear on the back.
I then have the opportunity to make inceremental upshifts all the way up without that big jump coming in.
On a flat bit of road I may be somewhere about 4 or 5 out of 8 on the back whilst on the big ring.
This is maybe doing say 18mph or thereabouts ?
If I need a very marginally shorter gear for an incline, what I can do is move onto the little ring but step up one at the back, it's almost like a half gear shorter.
Once I'm ready to step back up, it's onto the big ring again, but down one at the back. I then have the opportunity to add a little at a time and keep the legs in the very narrow zone where mine actually work![]()
I'm making this sound more complicated than it actually is, but it works for me and means that I'm not ignoring the big ring or feeling like it's a big step up. Helps get over that big gap on a compact setup like my road bike has.
nope, that makes perfect sense![]()
