Why are my daffodils not in bloom?
Mazz
Leicester
Bought a bag of daffodils from Sainsbury's last autumn,planted but none of them are anywhere near to flowering, they just look like long grass stems . I followed all the instructions.
Maybe they're late bloomers or just a bad bunch of bulbs. Any ideas?
Dave 123
Depends on the variety.
Also depends on where they’re from and who produced them. Year before last the ones we bought from a local garden centre were as blind as bats.
Julia9054
Knaresborough
Maybe give them time.
I put loads of daffodils in my garden about 6 years ago and this year is the first year they have been anywhere near decent.
I used to joke that I had a host of golden daffodils . . . one at a time.
Some years they have barely flowered at all.
This year they've had a meeting and decided to collectively pull their finger out.
(Disclaimer: I know bugger all about gardening)
PeteXXX
Hamtun
I got a bag of mixed bulbs last autumn, planted early December and they've all bloomed with some on their way out already!
annedonnelly
Girl from the North Country
Canonbie
The ones in my front garden (unknown variety) are always later than any others locally, but put on a great show.
I think sometimes they can be "blind" in a particular year because they didn't build up enough energy in the bulb the previous year. I'd give them a year or so to settle in.
Oh, and a tip for getting bulbs is to watch out for council workmen removing them from display beds. They just bin them so if you ask nicely they should be happy for you to take some - it's mainly tuilps they use round here, some of them are very smart.
tom73
Yorkshire
My old foreman was a national champion grower so I learned a thing or two about them over the years.
Depends on the variety and if they are single or doubles, doubles always flower later. The quality of bulbs is also issue many of the mass market ones can be hit and miss. It maybe they simply are too small to have flowers the first few years.
Do they have any flower steams or are they just all leaves? It can also be down to the weather.
The issues of when they go blind generally after having flowered for years before. Is mostly down to "mothering up" which is when the bulb producers more bulbs around it which are too small to flower.
Weight on the bulb will stop most this , most Daffs are planted way too shallow. Ask any one who shows them and they will tell you they plant deep. No less than 18inch my foreman had all his 2ft deep. I always planned them deep and never had an issue until narcissus fly killed the lot off.
Generally best way to care for them once flowered nip off the dead flower head. Stops them trying to make seed keeping all the engery for building up the bulb. Feed them with a good handful of potash around the base.
What ever you don't tie up or cut the leaves off it a big no no. They need them to feed the bulb leave them to either die down or you can safely cut them off 6 weeks after flowering. Even if they don't flower this year I'd still feed them and leave them it will help to build the bulb up for next year.
On a side note if you want some thing a bit different and more natural looking plant a few of our native daffodils.
cyberknight
we have odd one here too, seems to be loads about and ours have only had a few flowers
oldwheels
Isle of Mull
Ones in my top garden where they are unseen by anybody else are in full bloom but the ones beside my front path are struggling.
@T4tomo my snowdrops are long past but the ones in the local graveyard are just about past.
All uphill
Still rolling along
Somerset
Our usually reliable daffodils have also had a bad year. Maybe 20 flowers from 200 bulbs.
The snowdrops were amazing, though. Masses of them.
I put it down to the exceptionally warm and wet winter here in SW England.
Our snowdrops weren't great, daffs seem a little better. Not sure it's bluebell time yet as we've not seen any. Our hellebore are putting on a great show this year though.
Daffs are bulbs, as such I believe the flowering quality depends a lot on the post flowering period the year before. If its been able to put a lot of energy into the bulb then it's got a better chance of flowering well. Sometimes when we've moved bulbed plants the next year they're no good as they're busy putting out growth to settle and set up for the next year. If that makes sense. Roots and leaves to produce a strong bulb for next year
scragend
I know naff all about gardening but I've noticed round here that, although some daffodils are out, a lot of them aren't yet. With the cold and wet weather we've had it seems to be quite a late Spring.
