Holdsworth
- Crewe, Cheshire
These are the hardest tyres that I've ever had the displeasure of trying to fit to my rims. The original Conti Sport contact (700x32c) wore out after 2500 miles and I wanted something a bit more durable and less prone to punctures. The Conti's were very light and slipped on easily but they got cut to ribbons after a short while as the compound was so soft and the kevlar belt very thin.
I was aware that Marathon tyres would be a little more difficult to fit than others but I wasn't quite prepared for how hard they would turn out to be. The first side slipped over the rim easy enough but the last few inches on the other length of bead wouldn't go on. I am aware that I would have to push the bead into the well of the rim every time I get further to free up slack, it works well in theory and with other tyres but I was getting nowhere with the these. The bead just popped back out without freeing up the slack I needed. The body of the tyre is very rigid and just won't let the bead sit right. The other problem was the bead I had just pushed on one side was unseated by pushing in on the other side, I ended up chasing it around the rim up to a point until the tension was enough to keep it in.
In the end I had to force the tyre onto the rim with a tyre lever. It is a big no no I understand but I had no choice. My thumbs ached so much and I got nowhere. The tyre eventually slipped over with a lot of persuasion from the levers, luckily the tube wasn't pinched although the levers are a lot worse for wear now.
I have seen the Spa cycles video using toes straps to hold the bead in whilst I push it on. This is pointless in my view as I will be stuck if/when I get a puncture out on the road in the dark in the middle of winter! I can see me breaking my levers just getting the bead off of the rimto get at the tube it is so tough.
Seriously though would it have been so hard for Schwalbe to add a few more mm of wire bead to help the tyre fit easier to 622 rims?
BTW these are the standard Marathon "Greenguard" and not the infamous "Plus". I thought the thinner puncture strip would help with fitting and comfort.
