Why are Brompton folding bikes so expensive?
Bimble
Bimbling along ...
I just wondered what makes a Brompton worth nearly a thousand pounds in comparison with many of the cheaper folders that are now available?
Is it the components? Frame materials? Great service if something goes wrong?
They seem to be the folder of choice for many, have a great following and are written about positively all over the place, so what makes the Brompton such an admired bit of kit at such a high(ish) price?
outlash
also available in orange
As the old saying goes 'you get what you pay for'. I use a Tern for around town and it's great for that, unlike a Brompton that people tour with and keep for many, many years..
It's good quality and all parts are backward compatible. We have two 2008 models in the house and they are still going strong. Also you get to feel good that you have supported British jobs if that matters to you. Still not seen another folder with a fold as neat, although I've not been looking.
Used to be the only folder that was guaranteed passage on a train was a Brompton as all others were too big.
Brommies fold up to a more compact size by using 2 frame hinge axes instead of the usual one. This means extra tubework, lugs and fittings. This complex hand-brazed structure is made in London, paying London rents, wages, taxes, effluent standards etc.
Brommies have far more unique components than most std 20" folders.
They are a high quality product,comparable with (usually beating) the best German and Taiwanese folders which themselves are not cheap.
12boy
Casper WY USA
There is much said about the fold and some bitching about the weight, but those frames and hinges are sturdy and durable. What I like about it is its capacity to carry weight, both a rider and cargo. You can carry a lot in the front, really driven mostly by what size bag is on there and some on the back as well, without compromising handling and safety. In fact, a heavy front bag stabilizes the steering some what. I think of mine, which I call my little goat, as a very efficient little cargo bike, which BTW are hardly cheap, either.
Kell
Expensive compared to what?
I resisted getting a Brompton and had three full-size folders before it.
My main objection actually wasn't the price (as at that point, I didn't know how much they were), but more the small wheeled thing.
The first one was bent out of shape when it was run over by a car, so I can't hold that against the bike. However, both of my Dahons cracked the seat tubes. One after 5 years (bought new) and one after 1 year (bought second hand while I tried to get someone to admit responsibility for the first one cracking. I failed).
Both bikes ended up being binned as there were no parts worth salvaging. I only kept the wheels as I'd upgraded them from the cheap vaguely, but not quite, round versions that came with the bike. My original Dahon was about £800, plus the new wheels at about £125 doesn't make it that much cheaper than a Brompton anyway. And the second one I bought from a mate who'd used it for about a week, for £150.
This is a picture of the second one I bought - which was a 2008. The one I bought new, was a 2009. Sure I've got a picture of the cracks somewhere, but not to hand.
When I eventually bit the bullet and got a Brompton, I wished I'd done it years ago.
There's nothing better suited to the purpose that's any less expensive. And actually, There's nothing I've seen that 's more expensive that's any better suited.
My only gripe is that when it's folded, it's not light to carry. And those little wheels do NOT make it easy to wheel about.
jay clock
Massive member
Hampshire UK
I have Brompton and a Dahon. Dahon not used once since I had the Brompton. The Brompton folds properly and rides almost as well when the front bag is on.
T4tomo
Mine is over 10 years old and still rides like its brand new. You get what you pay for.
All I've replaced in that time is a rear mudguard and a crank/chainring combo. Plus a few cables, chains and sprockets thru normal wear and tear. I recently upgraded the brake levers to the new style as they are better, but the old ones were still functional.
Profpointy
I'm after one but it's a pity the axle spacing isn't standard as the stock 3 speed seems a bit naff, compared with the kinetic 11 speed afline version - but that needs an entire new rear end henc is a bit pricey
jay clock
Massive member
Hampshire UK
If you want to be able to ride right up to the gate of the station as the front of your train is passing in front of you, get off and have the bike folded before the train has stopped, get a Brompton.
to be fair my Dahon folds fast but is huge and cumbersome when folded... and will not fit behind a seat on the train I used to take
CopperBrompton
Bicycle: a means of transport between cake-stops
London
There are folders that are compact when folded, folders that are quick to fold/unfold and folders that are great to ride. If you want all three, you're looking at a Brompton, and that's why they aren't cheap.
But I'd argue that they aren't expensive either. They last forever, so you can easily get the purchase cost down to £100/year or a little over eight quid a month.
