Psyclist
- Northamptonshire
Just wondering what size rear mech (Campag Veloce) i.e small or medium etc. is needed for a compact chainring? 10 speed.
Thanks.
Thanks.
It depends on what size cassette you are using, i think up to 27 you can use the short cage.
Personally i would not touch 105 i am a campag man, i am not sure what you can mix and match.Thanks Derrick. I'll look at cassette options. And would it be okay using a 105 chainset instead of a Campag one?
Usually yes, provided the Campag groupset is 10spd and not 11spd, since 105 is 10spd and an 11spd chain might not seat right.
Most chainsets can be substituted into any groupset provided the spd count is the same, the difference between what can be done and what is optimal varies though.
Thanks.
Cheers. Not very good on the tech side of bikes. What would you recommend? Campag or Shimano crankset? The Veloce is 10 speed, I've gone for a 12-27t cassette too, so will get a short rear mech.
What is a wrap range, my other half is using a 27 rear cassette on a short cage works perfectly.That is a wrap range of 50-34+27-12=31. You should get a medium, not short cage.
I used to run a 105 10 speed cassette on a complete Veloce groupset. It was absolutely fine.
FWIW I hated Veloce and got rid at the first chance I had and went back to Shimano.
Granted it' rider preference, but Campag is not for me![]()
I run a 12-27 Miche cassette (I don't think Campag do a 12-27) with a short cage Veloce mech (2007) vintage. 50-34 compact. No problem. I read in the Campag Tech Docs that the 2013 10 speed mechs (short and medium) can run a 30Tcog. Can't find any mention of 'wrap range'. How old is that Branford Bike article?
