cyberknight
- Land of confusion
Massive EDIT, thanks to all who posted before the edit as i have actually managed to get some answers..
C2W back on and i have convinced swmbo that if i do not get a new bike
Because mini ck w2 is on the way.
I have a choice of a trek 1.2, specialized allez 18 or the new boardman race
Boradman race £650
Fork
Bontrager Approved, carbon legs
Sizes
47, 50, 52, 54, 56, 58, 60, 62cm
Frame fit
H2
Wheels
Wheels
Alloy hubs, Bontrager Approved alloy rims
Tyres
Bontrager T1, 700x23c
Drivetrain
Shifters
Shimano Sora STI, 9 speed
Front derailleur
Shimano Sora
Rear derailleur
Shimano Tiagra
Crank
FSA Vero, 50/39/30 (triple)
Cassette
SRAM PG-950 11-26, 9 speed
Pedals
Nylon body w/alloy cage
Components
Saddle
Bontrager Affinity 1, steel rails
Seatpost
Bontrager Alloy, infinite tilt adjustment, 20mm offset
Handlebar
Bontrager Race VR-C, 31.8mm
Stem
Bontrager SSR, 10 degree, 31.8mm
Headset
1-1/8" semi-integrated, semi-cartridge bearings
Brakeset
Alloy dual-pivot brakes w/Shimano Sora STI levers
Accessories
Grips
Bontrager gel tape
Extras
Fender mounts
Specialized allez sport 18 £719
Specialized A1 Premium aluminum, fully manipulated tubing, smooth weld compact race design, integrated headsetREAR SHOCK FORKSpecialized FACT carbon, carbon legs, aluminum crown and steererHEADSET1 1/8" sealed Cr-Mo bearings integrated w/ headset, 20mm alloy cone spacer with 20mm of spacersSTEMSpecialized Elite-Set, 3D forged alloy, 4-position adjustable, 4-bolt 31.8mm clampHANDLEBARSSpecialized Elite, 6061 aluminum, 130 drop, 90 reach, 31.8mmTAPESpecialized S-Wrap, w/ gelFRONT BRAKEShimano SoraREAR BRAKEShimano SoraBRAKE LEVERSShimano Sora STIFRONT DERAILLEURShimano SoraREAR DERAILLEURShimano SoraSHIFT LEVERSShimano Sora STICASSETTEShimano HG-50, 9-speed, 12-25tCHAINKMC X9CRANKSETShimano SoraCHAINRINGS50 x 34TBOTTOM BRACKETWith cranksetPEDALSBlack cage, body & toe clips w/ strapFRONT WHEEL REAR WHEEL RIMSMavic CXP22FRONT HUBShimano 2200, 32h, QRREAR HUBShimano 2200, 32h, QRSPOKESStainless 14gFRONT TIRESpecialized All Condition Sport, 700x23c, wire bead, 60TPI, w/ Flak Jacket protectionREAR TIRESpecialized All Condition Sport, 700x23c, wire bead, 60TPI, w/ Flak Jacket protectionINNER TUBESStandard presta valveSADDLEBody Geometry Riva Road, w/ steel railsSEATPOSTSpecialized Sport, alloy, two-bolt clamp, 27.2mmSEAT BINDERAlloy, 31.8mm
Boradman race £650
- Approximate Weight (KG): 9.34
- Brake Type: Dual Pivot Caliper Brake
- Chainset: FSA Vero compact crank
- Forks: Full Carbon
- Frame Colour: Dark Blue
- Frame Material: 6061 Alloy
- Frame-: Lightweight 6061 double butted aluminium frame
- Front Brake: Tektro Dual pivot
- Front Mech: Shimano Sora
- Gear Shifters: Shimano Sora
- Gears: 16-20
- Gender: Mens
- Handle Bars: Boardman alloy anatomic
- Headset: FSA Orbit 1.1/8 Aheadset
- Hubs: Formula 32 hole Q/R disc hub
- Number of Gears: 18
- Pedals: Wellgo alloy body fitted with toe clips & straps
- Rear Brake: Tektro Dual pivot
- Rear Mech: Shimano Sora
- Rims: 700c Mavic CXP-22s black 32 hole disc rim with CNC braking surface
- Saddle: Boardman black with cro-moly rails
- Seatpost: Boardman 350mm x 31.6mm black alloy
- Stem: Boardman black alloy 31.8mm
- Tyre size: 23c
- Tyres: Vittoria Zaffiro 700x23c
- Wheel size: 700c
- Frame Size (cm): 51 - 54
Fork
Sizes
Frame fit
H2
Wheels
Wheels
Tyres
Drivetrain
Shifters
Front derailleur
Shimano Sora
Rear derailleur
Shimano Tiagra
Crank
Cassette
Pedals
Components
Saddle
Seatpost
Handlebar
Stem
Headset
Brakeset
Accessories
Grips
Bontrager gel tape
Extras
Fender mounts
