Which light to use with a bar bag?
Scoosh
Velocouchiste
Edinburgh
Not sure how high your bar bag comes, so worth checking out Busch & Muller, Fenix torches and a major light comparison done by some folks on YACF.
Audax UK have a big lights section too.
HTH :smile:
... and don't forget Ayups Roadie kit.
Are these to go on your Fratello ??? :smile:
Bugner
Bugner
Sarf London
Cheers for the ideas, I will have a look.
Not sure if I will be riding my Fratello in the dark, only on sunny, non dusty, non windy days:biggrin: Hopefully it should be ready in the next week or so!!
simon_brooke
Auchencairn
Bugner said:
Looking to purchase a light that will be able to be elevated over a bar bag, without the need of an extension bar.
I have come across the Hope Vision 2 http://www.brianrourke.co.uk/images/visledT2.jpg
and the PrincetonTec Switchback
http://www.princetontec.com/files/prod_hero_shots_slideshow/switchback1_1.jpg
Does anybody else have any other reccomendations?
TIA ;)
My barbag - a Carradice Super C - came with a T bar which clips to the bottom of the bag to carry lights. If you don't already have a bar bag i would recommend this - but check that it does have the T bar because apparently some of the Carradice bags don't.
I've attached a picture to this post, but as it's the first time I've attached a picture I'm not certain how it will work!
Randochap
Senior hunter
There are various attachments that enable lights to be mounted on forks, such as the cronometro nob.
There are various sources, but I chose this one because the page also illustrates various approaches to light mounting.
The ultimate answer to both bar bags and light mounting is the classical French approach, which puts a bar bag down low on a "randonneur" rack, which also has threaded bosses for attachments, such as headlights -- or, because the bag is down lower than run-of-the-mill HB bags, there is not such an issue of clearance on the bars. Still, it's much better to get the light off the bars, to a more uncluttered location.
This approach -- lower bag -- also improves handling a hundredfold.
rogerzilla
Do you have a lo-rider boss on the forks that you're not using? A dynamo light, and no doubt some battery lights, will bolt on there very securely.
I had one fitted to a pair of forks Argos made for me recently, purely for attaching a light:
