family guy
- KENT
Hello everyone
My first time writing to a forum, ever, so please be gentle with me. What I know about fixing bikes is the same level as repairing computers..... hit it with a bigger hammer! so I afraid you may have your work cut out if you chose to help me
so here goes.
I have an old Sorrento Diamond Back Bike and the gears keep slipping when under load, and at times the chain falls from the high to low gear with out me touching anything. I lost count the amount of times the chain as jammed and there is a bit of a rattle well in truth it sounds like a machine gun. I notice that some of the teeth on the chainset are worn.
My question is can anyone recommend a change of groupset for my bike.
I feel I might as well change the lot as I don't know how old the components are and would it be a false economy to change the bits has they break?
At present my bike has a Shimarno 200gs derailleurs front and rear, 48-38-28 chainset ( for narrow chains only) and 7 gear cassette.
My budget is very limited at moment as I am unemployed but any suggestions will be gratefully received.
regards to all and be safe out there.
so here goes.I have an old Sorrento Diamond Back Bike and the gears keep slipping when under load, and at times the chain falls from the high to low gear with out me touching anything. I lost count the amount of times the chain as jammed and there is a bit of a rattle well in truth it sounds like a machine gun. I notice that some of the teeth on the chainset are worn.
( which is not too difficult to do! ) I thought a freewheel has only 1 gear, and anything with more then one was a cassette, is this not the case?
to CC
