neilakee
Member
I have the creaky/clicking bottom bracket problem. I’m going to investigate it myself (first time) to see if it needs a clean/re-grease or replacing. Little bit confused as to the specific tools I need, especially which crank puller? I think I need these products;
Park Tool BBT-22 Bottom Bracket 20-Tooth Splines Tool.
32mm wrench to be used in conjunction with the above.
Crank puller, not sure which of these two and what’s the difference?
Park Tool CCP-44 Crank Puller For Pipe Billet Spindles Tool
Or
Park Tool CCP-22 Cotterless Crank Puller Tool
I have a 2007 Claud Butler Levante, sport commuter. See images.
Thanks in advance.
Or
Thanks in advance.
