Which bottom bracket spacers for this bike/chainset combo
jay clock
Massive member
Hampshire UK
I am setting up a Ridgeback Panorama Deluxe as a tourer and installing an MTB chainset (Deore 36-36-26).
Frame is https://www.biketart.com/bikes-c1/frames-c33/ridgeback-panorama-deluxe-frameset-p12171
BB is 68mm and this model https://www.sjscycles.co.uk/bottom-...-hollowtech-ii-bottom-bracket-english-thread/
This site reckons two spacers on right one on left. http://off.road.cc/how-many-spacers-install-bottom-bracket-68-73-shimano-hollowtech-sram-gxp
Once in place the chainset visually looks a long way out, but I have not yet got the correct wheel in place (wheels arrive later)
Any comments or ideas?
jay clock
jay clock
Massive member
Hampshire UK
wheels are disc brakes but sure that makes no difference!
Bodhbh
No in depth technical knowledge here, bar using them for the last 10yrs, but 2 on the right, 1 on the left is standard with HT2 MTB cranksets and BBs and 68mm shells.
You’ll need to have a look at the chain line, when you’ve got the actual wheel and cassette in place, and it depends how big the spacers are, but 2 x 2.5mm spacers on the drive side, and 1 x 2.5mm spacer on the NDS, usually works.
Nigelnightmare
Usually 2 on drive side for mountain bike but if your putting a mountain bike crankset on a road bike frame then it's 1 on the drive side to get the same chain line.
As already stated its best to measure your chain line first.
jay clock
jay clock
Massive member
Hampshire UK
Thanks.. Will have a proper look at the weekend
