Where can I buy braze-on fittings?
un.hinged
Regular
Stoke-on-Trent
I went to my LBS today but they said they don't do fittings any more as they have stopped building frames. I want to mount a Shimano front mech and BB cable guide. I looked on eBay but I am not sure what the actual things I need to search for are called. Any help is appreciated. Cheers
Onyer
You can obtain clamp to fit your front mech http://www.merlincycles.com/shimano-braze-on-front-mech-clamp-55783.html
and the BB cable guide http://www.merlincycles.com/sm-sp18-under-bb-gear-cable-guide-62721.html
Always excellent service from Merlin
un.hinged
un.hinged
Regular
Stoke-on-Trent
Thanks, that cable guide was just what I'm after. Although I am unable to use a band type front mech due to the hefty seat tube diameter (40mm), hence my search for a steel frame fitting that can be brazed onto it
un.hinged
un.hinged
Regular
Stoke-on-Trent
Front mech arrived today, so I can start modifying it to fit. Got the cable guide ordered now that I'm sure I'll be using a bottom pull mech. Let the tinkering commence.... thanks again ;)
