When to replace chain
benb
Evidence based cyclist
Epsom
I belive the prevailing wisdom is that you can get away with only replacing your chain when it gets to 0.75 on the chain wear tool, but if it gets to 1.0 you'll need to replace your cassette too.
Well my chain is at 1.0. Is there some way of telling whether my cassette needs replacing, or should I just do it anyway? What about the chainring?
How easy is it to replace the cassette? Can I do it myself or is it an LBS job?
BSRU
A Human Being
Swindon
Yes 1.0 means chain and cassette.
Replacing the cassette is dead easy, aslong as you have the correct tools, ensure you have the correct cassette removal tool for your cassette, as far as I remember a chain whip is handy, a vice is very useful plus those interent video's showing you what to do.
Chainrings last alot longer than cassettes, so probably still fine, again the internet has lots of useful information/pictures/video's to help you decide.
IMHO a chain can have quite a lot of wear before it needs replacing. In the old days, (where I live), the best way of guessing wear was to pull it away from the chain ring and look at the gap. They rarely snap. I have had one go in 30 years.
But it is the cheapest bit to replace, if it does not distribute the load evenly it will wear other components, so how much do you value those ?
The other thing to consider is what you are doing with the bike, I take the old racing chains and put them on my commuter/training bike.
The front chain ring shows wear where you apply most load, two places. Look at the teeth and see if they are the same all the way round, if not its worn. If you leave it on long enough the teeth go like a hook and its difficult to change up and down on the front.
The back cassette is dead easy if you have the right tools. A small device on the Shimano fitting drops in the middle and then you unscrew the locking ring. I did mine by hand. The sprockets lift off, the splines on the shaft and the slots in the rings are arranged so that a monkey can put them on. You can't flip them over. Spacers are important to keep the gaps the same.
If you use only one gear it will wear a lot, if you use a lot of gears you will get less wear. Look at the teeth, do they look the same ? If not its worn. Usually the smallest sprokect gets used least, use it as a reference.
If you have one of the old type bodies on the cassette which unscrews by putting a chain with a leaver attached on it and wrestling it off the LBS might be a better bet, but I have not seen one of those for a while. (Except on one of my bikes).
If you have no problems and you are not racing don't worry about it. If it's jumping and the changer is aligned correctly start looking for bits to replace. May be I'm just a bit tight fisted.
benb
benb
Epsom
I think I'll take a stab at changing it all myself, and I can always take it down the LBS if I make a hash of it.
