EasyPeez
- Cottingham, East Yorkshire
Recently I'm finding on my 'best' bike that the front derailleur is not quite moving across as far as it once did so that, when I'm on the 50t cog at the front and in the highest couple of gears (smallest cogs) on the back the chain is just lightly rubbing on the inside of the mech.
Similarly, on the rear it's showing reluctance to drop onto the 11t cog - I think this is a separate issue rather than being caused by the front derailleur rub, but I could be wrong.
Could these be signs that my cables are ready for changing?
I've tried adjusting cable tension with the barrel adjusters and starting from scratch with the indexing, but with no improvement. I'm proficient at indexing and the gears are otherwise changing just fine. I keep the bike, including the cables well cleaned and oiled.
The bike is coming up to 4yrs old and 11,000 miles, so the cables certainly don't owe me anything. I've never considered changing them before simply because everything has been in good working order.
I'd be interested to know how often others change their gear cables, if there are symptoms that cables are getting past their best to look out for, and if the slight issues I'm now having might qualify as such symptoms.
Also, if it is time for a change then I assume inners and outers ought to be done at the same time? And at 11,000 miles, does it make sense to change the rear derailleur at the same time? The jockey wheels and the mech itself all seem fine, but then I would have said the same about the cables until a couple of weeks ago...
Cheers,
Andy
Cheers,
Andy
