Bought this from Sigma Sport for £89 the other month. Used twice and now no longer needed.
Drifts fit the following BB shell sizes:
BB30 (42mm)
PF30 (46mm)
BB86, BB92 (41mm)
BBRight (46mm)
BB386EVO (46mm)
Cannondale BB30A (42mm)
Cannondale PF30A (46mm)
Specialized Carbon OSBB (46mm)
Specialized Alloy OSBB (42mm)
Trek BB90, BB95 (37mm)
PF24 (41mm)
Drifts fit the following sealed bearing inner diameters:
22mm
24mm
30mm
Great bit of kit and amazing quality (the handles spin forever on the threaded bar).
£75 posted.
Easy to use, the Wheels Manufacturing Professional Universal Bottom Bracket Press Tool is constructed with two aluminium handles, uses a 1/2" rod and features two machined aluminium drifts.
Versatile and compatible with a range of bottom brackets, up to 132mm wide, including Wheels Manufacturing models, the press eliminates the need to hunt around for the correct size drifts and parts. The steps on the drifts are marked with diameter sizes, making matching the drift to your cups a simple task.
The zinc plated 1/2" diameter threaded rod is designed to resist bending, ensuring the cups to align and press in straight.
BB30 (42mm)
PF30 (46mm)
BB86, BB92 (41mm)
BBRight (46mm)
BB386EVO (46mm)
PF24 (41mm)
22mm
24mm
30mm
£75 posted.
