Slugmeister
- Leeds
I own a cannondale touring bike and am a novice mechanic. I recently serviced the rear axle bearing housing. I took the cassette off removed locking nuts both sides by mistake. Removed drive side cone and removed axle. I cleaned the ball bearings, locking nuts, axle and cones with foaming chain cleaner and wiped both bearing housings with a rag. Put everything back on but can't get the drive side locking nut tight anymore. Wheel has no play when secured in with quick release skewer. The problem is now the whole wheel and disc have turned. The very front has gone left a few mil and the very back has gone right a few mil. This means my wheel is going slightly left and the disc brake is rubbing constantly on the outer pad. Not sure at all what's caused it and reluctant to take it to a mechanic as its my transport every day. All help much appreciated. Thankyou
