Wheel Conversion - Freehub Help
Alex1982
Scotland
Hi
I am looking for some help with converting wheels from one of my bikes to the other and vice versa
1st Bike is a BMC Roadmachine with SRAM Components and a set of fast forward wheels
http://balfesbikes.co.uk/bikes/road...two-force-axs-road-bike-2022-in-bronze__29227
https://www.tredz.co.uk/.Fast-Forwa...rake-Carbon-Clincher-Road-Wheelset_263813.htm (Sram XDR)
2nd bike is a Bianchi Oltre XR3 with Shimano Ultegra
https://www.bikesheduk.com/product/117453/bianchi-oltrexr3cvdisc-ulteg-50-34r418/
I want the FFWD wheels to be on the Bianchi and the Bianchi wheels on the BMC
Which free hub would I need to put the FFWD on the Bianchi and the Shimano wheels on the BMC?
Thanks
Sharky
Kent
Not really qualified to answer this, but I've always understood that SRAM and Shimano cassettes are compatible.
But of your two bikes, one is 12 speed and the other 11 speed. So you will need to swap the cassettes over. If one needs a new freehub, then so will the other.
Have you taken both cassettes off and proven 100%, that they are different?
Good luck
T4tomo
SRAM and Shimano 11 speed are compatible to the extent they use the same rear cassette and chains
sraM12 spd needs its own XDR hub body, which will be on the FFWD wheels.
You will need to get one that fits your "whatever" wheels on your Bianchi - i,e an XDR hub that is compatible with that wheel. You can then put the 12 speed cassette on it and put on the BMC
Unless the spline are different I think you can put the 11 speed cassette onto the XDR hub on the FFWD, but you need a 1.85mm spacer behind it. you can test this bit before parting with any cash for the other bit.
