Hi !
This is a question for the people who are wheels builders and love to work on their wheels. Its a bit long pleases bear with me !
Rear Wheels.
I have been building wheels for recreation, and since I have a few bikes of my own it was nice to work on my own wheels. I have also built wheels for friends too.
Okay , current scenario is standard 700c rims middle range eg alex, , and straight gauge spokes. No fancy hubs.
My spoke calculation method seems pretty accurate and I don't land up with short or long spokes.
My findings are :-
Case 1. A friend used to break spokes on the rear wheel of his hybrid, drive side, I rebuilt his rim with new nipples and his original spokes, and brought it up to tension. (by feel), the wheel held strong and still is running good after 10 months. I checked this bike the other day with a tensiometer (park tool)and the deflection was really high. The rear drive side was showing almost 120 kgf to 180 kgf. the Non drive side was 96 kgf to 120.
Question:Now this gets me thinking, if at such high tensions the wheel stood good, then at what tension variation does one build a wheel ?
Case 2 . I built some wheels for my Surly build (w/out a tension meter)just by feel, I did not keep the tensions high and after riding her for 100 km found the non drive side spokes of the rear wheel went loose, I tensioned the wheel with a tension meter to about 130 kgf on the drive side which resulted 75 kgf on the non drive side. Then i mounted the tire which is a 700 x 41 knard, after inflating to 70psi, I rechecked the tension and found that the drive side had fallen from 130 kgf to 105 and the non drive side fell from 75 kgf to 68 kgf.
So I assumed this is what must have happened, the last time the tensions must have been good but after mounting the tire the tension went down.
Question : Has this happened with any of you as well ? Its a little confusing to keep the tension higher just to accommodate tire inflation ! !
Case 3 : I have an old decathlon bike( hybrid) which has served me well, and is still a great ride. I have been riding this bike for about 3 years, in this duration , i just broke a single spoke on the rear wheel. All good so far. The other day out of curiosity I checked the rear rim for spoke length and spoke tension , to my surprise, the spokes were very short and the manufacturer had tried to compensate it by using 16mm nipples which just hid the threads. The spoke tensions on the drive side were high at almost 170 kgf.
Question : Short spokes, too high tensions , shouldn't this wheel have issues ? I have ridden her for very long and the wheels are bullet proof !
Am i missing something here ? Whatever little I have read about wheel building just doesn't add up in these cases. Therefore I look up to you learned wheel builders and aficionado's for answers. I really love wheel building and need to make them so right .
Thanks for reading through , looking forward to your replies.
Rear Wheels.
My findings are :-
  Maybe a pro cyclist could tell the difference, but probably for ordinary people, I wouldn't think so.
