DSK
I have case open and a wheel manufacturer, who has replied with some interesting points that, I was not aware of mechanically.
'... wheel 'x' uses low contact seals to reduce rolling resistance in the bearing. These are not resistant to water, so care must be exercised when washing that water does not enter the hub internals. If it does, it must be dried or, you run the risk of water penetrating the bearings and drastically reducing their life. ……………………… If you feel that the low contact seals are not suitable for your preferred maintenance habits, I would consider using - 2RS seal type bearings instead of -2RU.'
I keep my bikes clean and spot less but, do not use pressure washers or blast a water hose gun close upto the bike. I always blow dry it with a garden blower after rinsing. Neither are they abused or used in wet or rainy weather. Sunny days only. The current bearings are sealed, whilst there is no sign of play, noise or issues, there may be a potential bearing issue occurring under load.
So a few questions for you technically superior beings.....
1. How does one clean a bike (chain/cassette degrease and wash), with it all intact on the bike and prevent water getting into the hub internals?
2. What is a -2RS bearing? (or equivalent that I can buy for my road wheelset that would be resistant to water)
3. I am looking to get a basic road bike (e.g Specialized Allez/Giant Defy) to use as a hack this coming winter. What all weather wheelsets are available and what at the key features one should look for if bearing specifications are provided to protect again rain/water?
