What's your maximum horse power?
Yellow Fang
Reading
1 HP = 750 Watts (more or less). I am sure I regularly did over 400 W on the spinning bikes when I went to spin sessions. With a superhuman effort, I suspect I could top 500 W (⅔ HP).
Horsepower.jpe
Rob3rt
Man or Moose!
Manchester
Rather useless, but since the thread is here, I had a look at my data and the power I can hold for varying durations returns the following.
Duration - Power (W) - Horsepower (based on your OP)
1s = 981W = 1.31
10s = 840W = 1.12
30s = 605W = 0.81
1 min = 500W = 0.67
5 min = 390W = 0.52
20 min = 325W = 0.43
60 min = 308W = 0.41
I am a weak sprinter!
GrasB
Nr Cambridge
Rob3rt, how did you get your 1s power? PT, Quarq & SRM power meters don't really sample down to that time span. They average the forces over a longer period & produce a data point at a higher frequency.
1s = 1.73-1.91 (1289w-1424w) - depends on where you chop the pedal strokes.
5s = 1.70hp (1264w)
10s = 1.37hp (1019w)
30s = 1.17hp (873w)
1m = 0.89hp (662w)
5min = 0.60hp (448w)
15min = 0.55hp (409w)
60m = 0.5hp (371w)
Rob3rt
Man or Moose!
Manchester
Quarq and I just lifted from my data, not something I have thought about tbh. Also these values are lifted from training efforts where they were part of some other effort (e.g. the best 1 minute power could have been the best section of a 2 minute effort), only the 5 mins, 20 mins and 60 min values have been formally tested as standalone efforts so it is highly likely that most of the shorter durations are not accurate. Additionally the 5 minute, 20 minute and 60 minute powers are turbo trainer values, I have exceeded both the 20 and 60 minute figures in 10 and 25 mile TT's by a little bit, but not enough to warrant an increase in my FTP value in my software as I would be unable to replicate in training on the turbo.
GrasB
Nr Cambridge
Quarq and I just lifted from my data, not something I have thought about tbh. Also these values are lifted from best efforts during training, only the 5 mins, 20 mins and 60 min values are tested to maximal effort.
IIRC you 1s will be 2 crank revolutions. So the actual measurement will be dependant on your cadence but is 'true' for that period. SRM are 1.5 revolutions & pessimistic, in some way this is the best instantaneous measurement, as it gives you minimum peek power (:blink: does that concept make your head hurt? it does mine). PTs are just funky as they go by time & various versions have different sample periods. This is why 5s is really the lowest sample period you want to deal with.
Yellow Fang
Yellow Fang
Reading
Someone at work shoed me an article in 'Top Gear' magazine that had an interview with Chris Hoy.
During tests, he'd generated over 500Ib/ft of torque:wacko: , as it said; 'more than a Ferrari (whatever model..)
HP = RPM x lb in / 63000
HP = RPM x lb/ft / 5250 (I think)
So for Chris Hoy,
HP = RPM x 500 lb/ft / 5200 = 0.0962 lb/ft x RPM
What is Chris Hoy's revolutions per minute?
ColinJ
Puzzle game procrastinator!
1s = 98.1W = 0.131
10s = 84.0W = 0.112
30s = 60.5W = 0.081
1 min = 50.0W = 0.067
5 min = 39.0W = 0.052
20 min = 32.5W = 0.043
60 min = 30.8W = 0.041
I am just plain weak! :laugh:
GrasB
Nr Cambridge
Depends how fast he is going, fixed gear!
Track sprint cyclists tend to have a fairly constant maximum power over a wide rpm range, as in 30-150rpm. I'd imagine that would be fairly low in the rpm registers, bellow that the pedal for tends to stay constant & power rises. Say he puts out 500lb/ft at 10rpm that's 0.96kW, but at 30 rpm that'd be 2.89kW.
