What's the difference between these Lezyne pumps?
kalniel
Herts
The first one is a 130 psi presta only pump, the other 2 are presta and Shrader, but only pump to 120 psi. The main differences are the dual valve fit on the Tech and Pressure drive. I got myself a brilliant little pump from Aldi, which is Shrader and presta, and is switchable from high volume to high pressure, it's brilliant.
kalniel
kalniel
Herts
OK thanks. After some more research I think I've got it:
Road drive = higher pressure, comes with presta screw + slip.
Pressure drive = all aluminum, presta+shrader
Tech drive = aluminum with plastic (sorry, composite matrix) end caps, presta+shrader.
Deleted member 35268
I have the road drive pump, its faultless.
