what will i use?
jim55
glasgow
hi peeps :thumbsup: ..my crank is threaded ,,the pedal is fine but the thread in the crank arm is gubbed ,,now iv tried to drill the pedal spindle and fix it in place with a bolt and its impossible to drill :angry: does any body know of any product to join these together lika a glue /kinda paste thing ?obv the worst case il have to buy a new crank but its a rat bike and i dont want to spend on good kit ,,any ideas peeps :wacko:
New crank. You don't want a pedal falling off. Sjs cycles sell single cranks.
Bobtoo
There will be a Loctite product that would probably do the job but they are quite expensive, it might be worth cadging some (as in take the bike in with you) from a friendly engineering works or old-style garage. I don't think you could ever trust it though.
Is there anybody near you that does bike recycling? There's one near me http://www.fifebikeworks.org.uk/ so I'm sure there must be more.
jim55
jim55
glasgow
helicoil was my first thought its prob gona cost a fair bit :blush: but good tip on the recycling thing ,,theres a few cleansing yards and i have acess (i work for the council)so il check them out (forgot about them ,,thanks)
rualexander
Would you ever be able to trust a repair sufficiently?
A helicoil would probably be ok but anything involving any kind of glue/bonding agent would always be a bit of a worry and you'd have to replace it eventually anyway when the pedal bearings go.
If its a left crank, you can get a new one from St John Street for about £10, otherwise New crankset from Spa for £20, if they are compatible with what other components you have.
