My son's 15 year old British Eagle mountain bike has play in the crank arms so I am assuming a new bottom bracket is needed.
I had a quick look on the drive side and it seems to come apart with a spline tool. However the spline nut that holds this side of the bottom bracket also seems to be holding a mounting plate for the front derailleur, which seems a bit weird. Has anyone seen this before?
On the non drive side (I didn't remove this crank as I didn't have time), there seems to be a locking ring (a ring with several cut-outs around the outer edge). What tool would I need to remove the part on this side, or will it be the same spline tool?
Is it likely that the bottom bracket is a cartridge type (15 year old MTB) and if so how do I know what size to buy?
I'd like to do the job myself is possible so any advice would be appreciated.
