What threads and sizes on Carrera hybrid
rockyraccoon
I'm trying to fit a set of stronglight mudguards onto my other half carrera hybrid bike but the set didn't come with enough bolts and the ones which are already in the bikes eyelet are too short. Therefore I need to buy some bolts/nuts/washers/screws but I don't know which size to ge.
I would be grateful if someone could help me identify thread/size for the following:
Front mudguard / forks
The eyelet's forks screws (need to be long enough to fit the SafeClip - black plastic thing that holds V-stays)
The bolt that will fit in the fork (to attach the front mudguard to the fork)
Rear Mudguard
The bolt to attach the rear mudguard to the area on bottom bracket area
The bolt to attach the rear mudguard (using slide bridge provided) to the frame between the two seat stays.
Cheers
rockyraccoon
rockyraccoon
I've done a bit more research. I believe M5 is standard for mudguard, rack and bottle cage screws.
