What size tyres
proletaratOne
I have a bike that has 18 mm internal rim width and 25 mm outside
What size tires fit in there best to give a nice aero mate with the outside of the rim
I want to run tubeless
Cycleops
Accra, Ghana
The current trend is for wider tyres run at lower pressure for a more aero profile. This would seem to be at odds with thinking that says narrower tyres run at high pressure are better. 28c tyres are the popular choice.
I'm not really qualified to give to the pros and cons but I'm sure someone will be along to give you the run down. In the meantime have a read of this: https://www.cyclingnews.com/features/why-wider-is-better-the-death-of-23c-tyres/
28c should be fine on those rims. The other thing to consider is does your frame have the clearance? Are the rims tubeless ready?
Hello!
Are the rims ready for tubeless? Can't just choose it, the rims have to be correct.
Aero: why? Not a rude question. Are you racing? If not, 28s will be fine and comfortable, or 25s if you must. 23s if you have no loose fillings...
My 'fast' bike (meaning that it's actually a real road bike, I'm not capable of riding it fast) is limited to 25s. The other bike, a steel mixte (just as fast, or slow, with me on it!) has the same wheels, but can take 28s.
28s all the way for me, but I'm no speed merchant. :bicycle::bicycle::bicycle:
raleighnut
For aero you want as close to an aero foil shape as possible. So the rim should be the widest part, that means 25mm or 23mm for the tyre.
Yep got 25mm on my Roval Classique Pave wheels (25mm outside rim width) for that very reason
585985
P
proletaratOne
Hello!
Yes I will be racing....that’s the plan... so trying to build a faster bike
P
proletaratOne
Thanks fellas for the answers and advice. I’ll be going with 25s
