What size of frame do I need?
Simba1off
Hi
Looking at getting myself a road bike!
I'm in bare feet 5'11" can anybody advise me on what size frame I should be looking at?
Thanks
gaz
Cycle Camera TV
South Croydon
What is your inside leg measurement?
It will be either a 56 or 58cm
biggs682
Northamptonshire
thats a tricky question , try first for comfort then ask re size , new (sloping tube) or old style flat bar tybe of bike .
i am 5ft 10" and all my old steel bikes are between 22 - 23 1/2" just depends on each design so try first then ask is my advice
slowmotion
Quite dreadful
lost somewhere
My 2p is to go and have a brief test ride after the LBS ( and that includes the big High Street players) has vaguely set up a couple of different sized frames. They should be happy to do that. If you buy off the web, you can't do that, but you will probably get a cheaper bike that may or may not fit. You will not get a free two month first service thrown in, however.
Test rides and a service are worth something.
Zoiders
I would err on the side of the 56, you can make a 56 a bit more roomy with more post and stem - you can make 58 a bit smaller with less post or stem but you can lose stand over height and steering can get a bit quick with a shorter stem
If it helps I am 5'10" with longish legs and I ride a 56, no problems so far and plenty of reach.
