What size cone wrench for Shimano RS80 C24 wheels.
Graham1426
West Midlands
Just purchased the above wheels but feel they have come out the factory over tight, and would like to know what size cone wrenches i require to dial them in.
Cheers
Graham
Don't know for sure but most likely 15mm and 17mm. Repack with grease while you're doing it, they never put enough in in the factory.
HovR
Plymouth
Most packs of cone spanners come with 4+ sizes, and are often cheaper than when bought individually. Take a look on eBay, that's where I got mine - Only £12 or so for 4 double ended spanners (with repeat sizes).
You'd find it useful to invest in a decent electronic vernier measuring caliper - I have found mine very helpful numerous times when working on the bike and buying new parts etc so I know what size to buy.
Alun
Liverpool
It's a fiddle to get the bearings correctly tightened, as you seem to need three hands.
Otherwise no problem as long as you don't lose any ball bearings.
Pack the bearing with grease as that stops water getting in even if the bearings don't need it all for lubrication. Any excess will just get squeezed out.
Check the tightness when the wheel is on the bike and the QR is done up as this will effectively tighten the bearing.
Make sure the locknuts are TIGHT on the cones, otherwise the cone might rotate and seize the bearing.
I've just remembered why I like cartridge bearings now.
