What psi in the rain
RyanMcGrath
Hello guys I'm doing a cycle event tomorrow and seen it's going to be heavy rain. The rain doesn't bother me but unsure what psi to run my tyres. Any advice will be appreciated
Cheers
ianrauk
Tattooed Beat Messiah
Rides Ti2
Your usual PSI you run them at (assuming it's between the min/max as stated on the tyre) will be fine.
VamP
Banned
Cambs
You get better grip in the wet at reduced pressure. I go 80 front, 90 back in wet weather races. Wet crits at 120 psi would be quite sketchy. Wet sportive at 120 psi will probably be fine.
Rob3rt
Man or Moose!
Manchester
A short sharp dab or a long dab? Accuracy matters
Doesn't matter, it is just to trick yourself into thinking it matters!
I'd personally drop the psi a bit but you have to way up the p'ture risk, fortunately for me its quite low and I find the extra grip good. Overall I tend not to be too bothered about psi, pumping to around 95/105psi and only topping up once a week or less often if its icy.​
Supersuperleeds
Leicester
