Probably cheaper than buying a big tub of red greaseperhaps time to get new tubes before it starts to get porous
Vaseline is mineral grease and will rot rubberI would have thought that vaseline might be okay as it used on babies, I also use when I get chapped hands so I would have thought that it should be free from nasty chemicals likely to damage the inner tube.
No more !!! That is WAY too much information !Talc.... Talc.... Talc.
Lash it around your tyre, puff it around your hole. It stops stuff sticking, it lets the tube move and inflate nice.
It smells good and you can use the rest to stop your ball sack / breasticles chaffing/sticking.
http://medical-dictionary.thefreedictionary.com/cyclists+nipplesNo more !!! That is WAY too much information !
As for the OP you could just try buying some new vale cores - only a couple of quid for a pair with new caps too.
Vaseline and latex don't mix well especially if you want contraception to be effectiveVaseline is mineral grease and will rot rubber
Are you suggesting KY Jelly for valve seals? Actually might not be a bad idea.Vaseline and latex don't mix well especially if you want contraception to be effective
